Need current regulator circuit for 300 vdc, 1 mA
Greg52556
Joined Dec 7, 2014
4
Anyone know of a circuit (or component) to regulate my 300 vdc to 1 mA as the load decreases? I am doing electrolysis and the load decreases as the process continues, due to ion formation.
38,549
You forgot power dissipation. At 300V a 10k ohm resistor will draw 30mA and dissipate 9W so you will want to increase R2's value. Since you only need 1mA, you could increase R2 to about 10meg ohm or so.
Greg52556
Joined Dec 7, 2014
4
So to confirm:
R1 stays at 10k ohm.
R2 should be 10 meg ohm.
This limits current to 1 mA with 300 vdc source.
What wattage should R1 and R2 be?
JWHassler
Joined Sep 25, 2013
308
I think the resistor ref-#s got swapped: R1 is the larger one. 10 megohms sounds good and will dissipate .009 Watts
R2 sets the current by R2=600/current_in_mA (approx 600 ohms) and dissipates .001*600 = .6 Watts
38,549
Yes, I meant R1 of course. :oops:
Note that the 600 ohm R2 emitter resistor will dissipate .001^2 * 600 = .6mW.
