need a tiny and minuscule hydraulic electricity generator!
JJoll
Joined May 7, 2013
49
I am working on a project and I need to generate a very tiny and minuscule hydraulic electricity generator.
I have not finalised it yet but I am looking to make something with following dimension: length=15mm to 20mm. Width=5 to7 mm and height=3mm to 6mm
Is there any of the shelf micro electricity-generator out there? If not, is it possible to home built one? How should I go about this?
thanks
wayneh
Joined Sep 9, 2010
18,119
Cellphone vibrators are tiny DC motors that can be found very cheaply, even free if you tear apart an old phone. But I wouldn't know how to mechanically adapt one to being a generator. You'd need to spin it fast to get much juice out of it.
Marley
Joined Apr 4, 2016
519
How much power do you need to generate? When you say "hydraulic" I presume you mean water. What pressure and flow rate do you have available? First thing to consider is the basic physics: you cannot get more energy out than you put in and if the device is miniature, the efficiency will be very low. Expect well below 10%.
Permanent magnet DC motors will work as generators. But cheap motors have poor magnetic coupling and have to spin very fast to generate useful power. One way to test if a motor will be any good is to short the motor terminals and to turn by hand. Compare to when the terminals are open. Any difference?
Brushless motors are better. Try this with a disk motor salvaged from an old hard disk drive. Short all 3 terminals together.
