Need a resistance sensor to trip relay
Nessmuk
Joined Mar 30, 2017
What I have is a sensor with two leads that make a circuit when immersed in water instead of fuel.
The leads are at most 1/8 inch apart.
The voltage is 12-13
The sensor has 220k resistance added to it.
I need to know what coil resistance the completed circuit will be able to overcome in order to activate a relay.
#12
Joined Nov 30, 2010
18,224
About 2.2 million ohms.
Except there is no such thing as a 2 million ohm relay.
What you're trying to do is called a conductivity measurement. It takes a lot more than a relay to use the conductivity of water as a switching point. At the very least, an amplifier, but it's better done with a bipolar square wave generator and then an amplifier. How are you at building oscilllators and using operational amplifiers?
Nessmuk
Joined Mar 30, 2017
I am trying to use a racor water in fuel sensor that has two wires to it. The sensor provides a ground signal when water completed the circuit across the tips.
I found the resistance in their literature.
Nessmuk
Joined Mar 30, 2017
Ok, let's forget it. I thought it was simple matter of triggering a relay from a low voltage ground.
The company sells a $150 part that lights an led and powers a buzzer. Obviously they want to sell those, not provide info to let me make one.
I had to do a lot of searching to find what I provided.
#12
Joined Nov 30, 2010
18,224
I don't think the converter is worth $150, but it's way more than just a relay.
Then again, I'm old. My sense of prices is stuck in the 1970's.:D
