Need a model of varicap FV1043
michael1978
Joined Jun 29, 2014
309
I am realy sorry, i put to much question here,
i just need a model of equivalent varactor of FV1043
somebody told me some book how to make a diode model in spice, but i search for free in google:oops:, but i did not find…..something similar to teach you to make a diode varactor model
THNX.
michael1978
Joined Jun 29, 2014
309
I have a oscillator 100MegHZ, with tuning diode, but when i change the voltage, he does not change the frequency in ltspice, the frequency stays the same, why, what for mistace i make?
Bordodynov
Joined May 20, 2015
3,431
And you added varicap to the library (in the file standard.dio). I already did it. You can put the model on the circuit, as I did when demonstrating the dependence of capacity on voltage. I put a voltage limiter because without a varicap limit a large voltage develops (more than 5 volts), and the allowable voltage for this varicap is 5 volts. This limiter lowers the frequency. It is better to use the dual Schottky diode BAS70-04. To obtain a larger output amplitude, you can enable several such limiters in series (for example, 3 BAS70-04).
michael1978
Joined Jun 29, 2014
309
yes i add it to library, now i understand
thank you very much……
Have a nice day and wekend....:):):);)
