NEC VT670 projector bulb lamp bypass to fix LED instead-need help
savage75
Joined Jan 4, 2017
5
I have NEC VT670 projector that i need help to figure out how to bypass the bulb checking circuit, please check the attached images. let me know if you have questions.
2016-12-31 15.20.00.jpg 2016-12-31 15.19.50.jpg 2016-12-31 15.19.46.jpg 2016-12-31 15.19.30.jpg 2016-12-31 15.19.19.jpg 2016-12-31 15.18.57.jpg 2016-12-31 15.18.11.jpg 2016-12-31 15.18.04.jpg 2016-12-31 15.17.45.jpg 2016-12-31 15.17.27.jpg
savage75
Joined Jan 4, 2017
5
Hi Dodgydave,
I just only need to bypass the bulb controller, i can fix very bright led with its own power. see the attached image.2016-12-31 15.19.19.jpg
savage75
Joined Jan 4, 2017
5
I found more information regarding the bulb controller (TDK MSE395/ 3N100612, its used for all the models VT 680 /675/ 470/ 670/ 675/ 676 )
Output Type: Dual
Output Power: 301 - 400W
is_customized: yes
Brand Name: VT675
Output Current: 1.8AOutput
Voltage: DC12v
Model Number: 3N100612
Output Frequency: 50HZ-60HZ
Input Voltage: 110V-220V
I was looking for service manual but no luck.
Dodgydave
Joined Jun 22, 2012
11,395
So 12V @ 1.8A is 22W max, looks like its just a smps provides the 12V dc, with two sets of output....so what's the other output for?
And what are you trying to achieve, just replacing the lamp with a high powered led, or replace the psu?
savage75
Joined Jan 4, 2017
5
Hi Dodgydave,
sorry for late answer, there is an plug with 15 port. i need to check what used for if i need to bypass the psu.
