My famous Lecher Wire demonstration
33,047
Definitely a nice demo.
So, for measuring the frequency of the signal, you used the speed of light in a vacuum. Can't the speed of the waveform in a conductor be considerably less than that?
Where are RF microammmeters available from commercially?
KL7AJ
Joined Nov 4, 2008
2,229
Howdy:
With wide spacing (high Z0), the velocity factor of the Lecher Wire is about 99% of that in free space, so the error is less than the calibration of my signal generator!
The R.F. microammeter is just a DC microammeter with a shottkey diode detector. (I actually have two of them in a voltage doubling configuration) A germanium diode will work fine too...I just happened to have a couple of nice Schottkeys. :)
ERic
davebee
Joined Oct 22, 2008
540
Many moons ago (around 1979) I took a correspondence course in radio electronics, and it included some Lecher line experiments.
My Lecher line was 3 foot of lengths of about 16 gauge wire stretched about an inch apart across a wooden frame. It had a little one-transistor oscillator of about 400 mHz at one end, and used a germanium diode detector on a circuit board that could slide across the parallel pair.
It worked great!
KL7AJ
Joined Nov 4, 2008
2,229
It worked great!
Hi Dave:
Glad to hear that! It's really hard to think of a simpler and more revealing experiment!
Eric
alfacliff
Joined Dec 13, 2013
2,458
I have been thinking of building a lecher line to use as a demonstration in my ham classes. I have been helping the local CERT team get liscensed, and I am a w5yi voulteer examiner. how about using a uhf rig, like a vx5 yeasu on very low power to generate the signal?
cliff wa0rox
KL7AJ
Joined Nov 4, 2008
2,229
cliff wa0rox
That works just fine. You might want to pad down the output a bit though.
LEDs do work, but they also draw some current, which upsets the current distribution on the line. You actually want a true voltage indicator....or as close to that as you can get.
ERic
