muting DM6000AR
panic mode
Joined Oct 10, 2011
5,480
i have tons of DMMs but that recently as given role of carry on is DM6000AR. that means it sees very little use. overal i like it but there are two major flaws, both of which could easily be fixed in firmware (ultimate goal):
1. this is an autoranging DMM and conversion is fast but calculated values is slowly (in 2-3 steps) fitted to display.
2. way to chatty... i only care about sound when doing continuity check, everything else is only annoying.
this is a low cost device with decent specs and therefore perfect candidate for hacking.
i have limited time but maybe this can inspire others and get them to chime in. here is what i found so far:
to access board, get under corner of red silicone and peel it off
remove kickstand (2 screws) (make sure to keep an eye on size and length of all screws).
remove battery
remove 4 more screws.
leave display and mode selector screws unless you really have a reason for it.
assemble in reverse order.
but since i am not the type that holds back:
IC1 is heart of it but it is just a die with blob on gunk so no part number. however, based on footprint and the way it connects to peripherals, this seem to be DTM0660.
an actual IC (not a bare die) would be DTM0660L.
IC2 is an eeprom
crystal is 4MHz (silkscreen shows 1MHz)
J1 and J3 seem to be programming ports. lets call pin1 the top one:
1 = GND
2 = Vcc (3V)
3,4,5,6 = signals
IC1 pins used to sense mode selector switch position are exposed as M1,M2,M3,M4 pads (J6 and J7).
"0" is 0V, "1" is 3V
buzzer is 9V, with low side switch (mosfet or bjt, with R25 connecting to gate/base).
so even without access to firmware one should be able to make a simple mute circuit just with 4 small parts:
two diodes (or circuit) with anodes connecting to M1,M2 and cathodes connecting to gate of N type mosfet (2N7000, AO3400A ...), and resistor such as 100k across g-s of the mosfet.
this N mosfet would would pull down gate of buzzer driver (right side of R25).
again, no time so implement it at the moment (it will have to wait for few days) but this should largely address one of the two points and - it is easily reversible if needed. will keep poking it when i have some free time. ultimately i would like to dump firmware, then try others (if found) and maybe even reverse engineer it as EEVblog did. then possibilities to make customization would have no ends (autoranging speed, RS232, USB ...)
