Murf1520 recovery diode
Feliks33
Joined Aug 22, 2017
Hi ! I am new here :) actually my occupation is Computer science but I gathered a bit knowledge from electronics, I have a broken welder, so I thought maybe I can find a problem myself, found this diode with corroded check point, so it became my suspect :)
Checked it with multimeter from both sides (polarity change) and it beeped (Long Beep or 0 resistance) from both sides, I know that diodes allow only one side beep defined by diode sign ->- ,never saw this diode so I don't sure how it behaves and can I check it at all with multimeter.
Uploaded a photo with a corrosion .
Help appreciated :)
Thank you !
Feliks
Dodgydave
Joined Jun 22, 2012
11,395
Diode should be tested out of circuit, lift one leg up, and test on" Diode" with multimeter, you should get 0.7V one way and open circuit the other way.
Feliks33
Joined Aug 22, 2017
I know, I can't take it out, there is a heatsink on the other side, what the difference if it inside the circuit ? still it has zero resistance from both sides. It is a 600v diode :)
