- Joined Jan 23, 2018
- 28,615
OK, here is another option, given that I have not seen any mention of transmission latency. Rather than convert a binary word into an analog voltage, why not have each input that is active set a specific voltage in one volt increments, so that outputs will be identified by a specific voltage from one to nine volts, and then an analog scanner sequentially selecting each point in sequence. Then on the receiving end each specific voltage reading can set a bit indicating which contacts are active. That scheme can simply be multiplexed by an analog data acquisition scanner, and on the receiving end be recorded as set bits entirely in software. And the whole system will not need to be synchronized.
