Multiple diodes circuit
linhvn
Joined Nov 6, 2024
297
,Assump that both D1, D2 conduct, V cut in all diodes 0.6V, I calculate V1=5-0.6=4.4V, then VR1 = 10-0.6-V1=10-0.6-4.4=5V, =>Ir1 =5/10=0.5mA positive means it follows the forward bias D1,is this correct?
Ian0
Joined Aug 7, 2020
13,132
Assuming D1 and D2 conduct. .. but how much do they conduct? What sort of diode are they? How warm are they?
ericgibbs
Joined Jan 29, 2010
21,444
Hi lin,
In order to check if the D2 is conducting, you must calculate the value of V1 when D2 is disconnected.
From the Voltages of +10V and -5V at the ends of the resistance network, what do calculate the total voltage across the 16.2k network.?
E
linhvn
Joined Nov 6, 2024
297
Hi lin,
E
D2 disconnected thus I remove the branch with D2, I also remove branch with D3 because no current through D3, the current through the R1, R2, R3 is = (10-(-5))/ (10+4+2.2) = 15/16.2=0.93mA
ericgibbs
Joined Jan 29, 2010
21,444
hi lin,
OK,
So what is the voltage drop across 10k with that current?
From that voltage drop value, you should be able to calculate V1.
E
Pyrex
Joined Feb 16, 2022
502
It seems that it would be easier to calculate if all the voltages were positive. Therefore let us modify the circuit a little:
Lets say, -5V source is the Earth.
Previous Earth is +5V.
In the same way, +5V source is +10V , and +10V is +15V.
Let’s calculate the voltages relative to the ground. The ground is 0V.
Let's disconnect the diodes D2 and D3 at the beginning of the calculation.
Then, the current through the three resistors will be : (15-0.6): ( 10+4+2.2) = 0.889mA
Voltage R3-R2 is : 0.889x2.2= 1.95V
Voltage R2-R1 is : 0.889x(2.2+4)= 5.51V
ericgibbs
Joined Jan 29, 2010
21,444
hi lin,
Yes,
A point to remember that the D2 diode will create a 0.6V voltage drop from the +5V.
Are there any more questions you need to ask for this topic.
E
