Multi-Stage Amplifier Project
bigyanengi
Joined Feb 24, 2024
37
The lower end of Rb and R1 should go to the negative supply, not ground. The top of Ra should go to ground.
How did you calculate R1? Isn't it supposed to have 5mA through it?
Then do the same for Q8, to set the output current.
Hi Ian, Looks like I got what I want. Is this seems to be correct now?
bigyanengi
Joined Feb 24, 2024
37
Hello Ian,
Actually I did missed some more and now is good. Please see the screenshot. I calculated R1 based on these assumptions
The tail current is set by Rtail in series with Q5, and it's essential to ensure this current is less than 5mA. Assuming Q5 is a transistor acting as a constant current source for the differential pair:
  1. Determine the Voltage Across Rtail:
    • Assuming Q5 is an NPN transistor and the supply voltage (VCC) is +5V, the voltage across Rtail would roughly be VCC−VBE where VBE is typically about 0.7V for silicon BJTs in the active region. Thus, the voltage across Rtail would be approximately 5V−0.7V=4.3V
  2. Calculate Rtail:
    • For a maximum tail current of 5mA, use Ohm's law (V=IRV=IR) to find Rtail:
    • Rtail=V/I=4.3V/5mA=860Ω
    • This calculation provides the resistance needed to ensure a tail current of exactly 5mA. To guarantee it stays under 5mA,
Ian0
Joined Aug 7, 2020
13,145
Hello Ian,
  2. Calculate Rtail:
No. What's the voltage at Vb1?
(and no, you haven't got a useful output - you have a peak-to-peak output current of only 700nA)
Ian0
Joined Aug 7, 2020
13,145
You have -3V the base, so you have -3.6V on the emitter, so you have 1.4V across R1.
R1 is 860Ω so current is 1.4V/860Ω, and that's not 5mA.
bigyanengi
Joined Feb 24, 2024
37
Hello Ian, when I calculated R1 was based on the 5mA current going assumption as I sent you the working before. So, decrease R1 to get close to 5mA current?
Ian0
Joined Aug 7, 2020
13,145
You have the same configuration as Q5, so the calculations are exactly the same, except you want 1mA not 5mA, so work out R3
bigyanengi
Joined Feb 24, 2024
37
Hello Ian,
I have done the calculation and with 1.5k ohm as R3 my collector current will be less than 1mA. However, I do not see a curve for Ic on Q8. What might have happened there? 1708811075608.png
Ian0
Joined Aug 7, 2020
13,145
Now you need to sort out the output stage. Get rid of Rc Rd Re Rf Q6 and Q7, and add a PNP common emitter stage. (The cascode will come later - personally, I think it's pointless, but it's in the requirements)
bigyanengi
Joined Feb 24, 2024
37
Hello Ian,
When I delete all existing Q6 and Q7 with their bias registers, the output from the first stage goes to the base of the pnp?1708812666200.png
Ian0
Joined Aug 7, 2020
13,145
Perfect. You can see you have LOTS of gain.
Now, just because you have to, add in the cascode. (I assume you meant cascode, as you said cascade)
bigyanengi
Joined Feb 24, 2024
37
Hello Ian,
With all these curves i got from the simulation. Is everything is set the right order? And How do I add the third stage?
bigyanengi
Joined Feb 24, 2024
37
Solve this problem first
Hint: where is the Emitter resistor for Q5
E
Hello Eric,
Sorry to bother you and you must be busy. IF you get a chance please look into my progress so far let me know If I am missing anything or of course from the assignment direction.
ericgibbs
Joined Jan 29, 2010
21,452
Hi big,
Those square wave plots are due to amplifier saturation of the 10mV Sine wave input.
The Current mirror type of load you are using for the Q1 and Q2 BJT's will give a VERY high gain.
Your circuit needs negative feedback to reduce the gain and make the amplifier stable.
E
bigyanengi
Joined Feb 24, 2024
37
Hi big,
E
Hi Eric,
Thank you for your reply. I will apply negative feed back from the output all the way back to the V1 note or to the output of first stage?
Ian0
Joined Aug 7, 2020
13,145
Hello Ian,
Before you add the third stage, you need to add the cascode (it's pointless, all it will do is reduce the output voltage, but it's in the assignment). Then you needs to add the emitter followers.
Look up "Complementary emitter follower".
Then you need to check you have enough gain and bandwidth before proceeding to part 2 in which you add feedback (as @ericgibbs said in post #38)
What time zone are you in? Perhaps you could fill in the details. Some of us might have been outside enjoying the Spring sunshine!
