Thanks a lotOK that is what I suggested. Does it compile? Looks like it did. Now add your lcd.c file to the project. Compile again.
I did the mistake I was not including lcd. file in project
Now it's working fine I can see text on LCD
code
Code:
#define _XTAL_FREQ 8000000
// PIC16F877A Configuration Bit Settings
// 'C' source line config statements
// CONFIG
#pragma config FOSC = HS // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = ON // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#define RS RD2
#define EN RD3
#define D4 RD4
#define D5 RD5
#define D6 RD6
#define D7 RD7
#include <xc.h>
#include "lcd.h";
void main(void)
unsigned int a;
TRISD = 0x00;
Lcd_Init();
while(1)
Lcd_Clear();
Lcd_Set_Cursor(1,1);
Lcd_Write_String("LCD Library for");
Lcd_Set_Cursor(2,1);
Lcd_Write_String("MPLAB XC8");
__delay_ms(2000);
Lcd_Clear();
Lcd_Write_String("Developed By");
Lcd_Write_String("electroSome");
__delay_ms(2000);
Lcd_Clear();
Lcd_Write_String("www.electroSome.com");
for(a=0;a<15;a++)
__delay_ms(300);
Lcd_Shift_Left();
for(a=0;a<15;a++)
__delay_ms(300);
Lcd_Shift_Right();
Lcd_Clear();
Lcd_Write_Char('e');
Lcd_Write_Char('S');
__delay_ms(2000);
