More Efficient then a Solenoid?
KCHARROIS
Joined Jun 29, 2012
312
Hi All,
It's been a while since I've logged in but I recently started diving back into designing circuits, nice to be back! I think solenoids are great but they consume a lot of power in my opinion. Is there anything out there that acts like a solenoid plunger but consumes a lot less power? Force behind the plunger is not a concern just the movement is of interest.
Thanks,
KCHARROIS
GopherT
Joined Nov 23, 2012
8,009
Hi All,
Thanks,
KCHARROIS
There are various motion control devices that can move a pin left right. What is your goal?
KCHARROIS
Joined Jun 29, 2012
312
Not only am I getting back into electronics I've also been getting into clocks. Trying to develop an electronic escapement with a solenoid type device vs a "hair spring".
Thanks,
Kevin
GopherT
Joined Nov 23, 2012
8,009
Thanks,
Kevin
Then you only need a quick pulse to maintain momentum of a pendulum, or, to ratchet a cog to the next escapement.
JUNELER
Joined Jul 13, 2015
183
What source you will use, a battery or ac adapter. This will concern only if using a battery.
But using a chargeable battery will not make sense of problems in power.
And what loads it will driven on load side is it ac or dc source.
KCHARROIS
Joined Jun 29, 2012
312
I think the the magnetic type solenoid would work wonderfully. I planned on using batteries. Maybe a 9V or two AAA1.5V not sure yet. Rechargeable batteries would be an option as well. Thank you for the great replies!
shortbus
Joined Sep 30, 2009
10,050
Get a "dollar store" battery clock with a second hand. Tear it apart to see what they use to make the movement. They sound like they use a escapment type movement when running and not a motor.
38,503
It is a stepper motor.
The sound you hear is simply the sound of the stepper motor moving one step.
KCHARROIS
Joined Jun 29, 2012
312
Why would rechargeable batteries not be a problem with power?
