Mono/stereo jack input led indicator
ekremgusani
Joined Mar 20, 2011
157
How i can ad led to jack female to lite when male jack is inserted?
So, when male jack is out the led is off and when male jack is inserted/connected to female jack the led lite as indicator.
DickCappels
Joined Aug 21, 2008
10,661
What kind of jack?
What signals are present on the jack?
If this is a modification of an existing circuit, please provide a diagram showing what connections are already made to the jack.
AlbertHall
Joined Jun 4, 2014
12,624
if you are talking about the common 2.5mm/3.5mm jacks then the socket can have switches built in which you could use to operate an LED but that depends on what else is connected.
ekremgusani
Joined Mar 20, 2011
157
I want to connect siren to 3.5mm stereo or mono jack so when the siren is inserted i want the led to glow and when the siren is disconnected i want the led to be off
ekremgusani
Joined Mar 20, 2011
157
What kind of jack?
It is 3.5mm with off on switch with led glow when the switch is on but i want to add one more led to glow when the siren is inserted into the 3.5mm jack and the led to be off when the siren is disconnected from the 3.5mm
Alec_t
Joined Sep 17, 2013
15,117
We need to know what else, apart from a LED, is connected to the socket and existing switch. What is the socket part of? What, apart from the siren, is the socket intended to have plugged into it?
ekremgusani
Joined Mar 20, 2011
157
I fixed by my self!
I connected pin of red rgb led to the one +pin of the stereo female jack, this led glow when nothing is inserted.
The green pin of the rgb led connected to the 2nd + pin of the stereo female jack.
The green led is glow when anything is inserted into the female stereo jack.
When nothing is inserted into the female jack then red led glows.
The cathode of the rgb connected to the cathode of the stereo female jack.
ekremgusani
Joined Mar 20, 2011
157
Well done.
Hopefully the rgb LED will survive direct connection like that (no current-limiting resistor is mentioned) and the LED won't introduce too much distortion of the audio input.
forget to mention 1k resistor to the rgb leds. working perfectly fine with no distortion, I am using that connection for music player and siren, no problems so far.
