I produce boards that can pilot some automation applications.
They are usually boards with a large dissipator beneath and they are divided
into a couple of sections: power supply, automation control, microcontroller and I/O communications. All these sections are integrated into one single board.
My problem is that I have to produce many boards with different specs. So for instance one board version could have just the power supply different, while another version of the board has only the I/O different or the micro.
That way, I'm obligated to produce many boards versions.
So i came up with an idea, which is to produce a different board for any section. A board for the power supply, a board for the automation control, one for i/o etc. And somehow connect the boards between them on top of the dissipator.
The problem i'm facing is to find a secure way to connect them. I cannot use a shield configuration like an arduino board or simply connect them with some kind of jumpers. That is because the boards have to work in a harsh industrial environment for a long time.
Do you have any idea of how can i achieve this kind of configuration? Basically what i'm searching for, is a cheap and safe way of connect these boards between them. Thank you in advance!
