Jerry-Hat-Trick
- Joined Aug 31, 2022
- 839
I think Alec_t and I are pretty much on the same page. I'm probably more of a "suck it and see" person, his testing advice is more professional! You have shown that connecting only one of 7 or 8 works. Maybe connecting them both would work, but there is a risk of damage. His testing with a "temporary resistor (~10k) between the 'grounded' pin and Vcc" makes a lot of sense. Just connecting one of 7 and 8 via a diode will show if the IC output is sufficient to turn the Mosfet on - but it may stay on giving full speed regardless of the PWM mark/space ratio. Try this first?
Looking at the schematic, the red wire should be connected to the 5V output of the 7805, the white wire at the top left to the receiver? Not sure I'm understanding where you are seeing 8.5V.
