First, new to this forum. I am a scale model boat builder. I have two working submarines and a few surface boats. I have made a few of my own PCB's for these boats, mostly to power LED's. The PCB's I made were done on a freebie computer program, printed out on clear overheard transparent mylar, then transferred to a PCB using a clothes iron, then etched. I am not that adept and diagnosing electronic circuit problems.
I have a motor speed control kit which is a kit from our model boat club. The kit was designed by a member that recently passed away so I cannot go to him about this problem. I attached the schematics, parts list and a picture of the two speed controls. After inserting and soldering all the parts all I get during testing is the relays clicking. In his instructions, it says to not solder pin 8 and 10 of IC1 which is a ZN409CE. That IC is in a socket so I did not solder those pins. Pin 10 appears to be power for the IC. Pin 8 is an output which is also tied to pin 7. So I am asking here, shouldn't pin 10 be soldered so the IC gets power? Is that the cause of the speed control not working?
