on this page:
http://www.allaboutcircuits.com/vol_3/chpt_4/2.html
this paragraph needs correction:
If the switch is open as in (Figure above (a), the base wire of the transistor will be left floating (not connected to anything) and there will be no current through it. In this state, the transistor is said to be cutoff. If the switch is closed as in (Figure above (b), however, electrons will be able to flow from the emitter through to the base of the transistor, through the switch and up to the left side of the lamp, back to the positive side of the battery. This base current will enable a much larger flow of electrons from the emitter through to the collector, thus lighting up the lamp. In this state of maximum circuit current, the transistor is said to be saturated.
it should read:
If the switch is open, as in [delete this parenthesis ( ] Figure above (a), the base wire of the transistor will be left floating (not connected to anything) and there will be no current through it. In this state, the transistor is said to be cutoff. If the switch is closed, as in [delete this parenthesis ( ] Figure above (b), [delete: however, ]electrons will be able to flow from the emitter through to the base of the transistor, through the switch, and [delete (erroneous): up to the left side of the lamp, ]back to the positive side of the battery. This base current will enable a much larger flow of electrons from the emitter through to the collector, thus lighting up the lamp. In this state of maximum circuit current, the transistor is said to be saturated.
a couple of paragraphs later:
.... More important[ly], the current-controlling...
.... Consider [the] Figure below, where a pair of solar cells provides 1 V to overcome the 0.7 VBE of the transistor to cause base current flow, which in turn controls the lamp.
in all cases, "Figure" probably shouldn't be capitalized, but that's a matter of style.
then:
Or, we could use a thermocouple (many connected in series) to provide the necessary base current to turn the transistor on [as] in [the] Figure below.
picture caption:
A single thermocouple provides 10s of mV. [what is "10s" of a millivolt?]Many in series could produce in excess of the 0.7 V transistor VBE to cause base current flow and consequent collector current to the lamp. [in good conditions, a thermocouple provides 50mV at very low current. an array of 14 pristine thermocouples seems like a bit much. really, that's a lot of flame. i'd change the example to some other sensor. but that's just me. i'd hate to see something catch on fire. ;-) ]
picture caption:
Amplified microphone signal is rectified to DC ["in order to" or "to"] bias the base of the transistor providing a larger collector current.
lastly, one of the bullet points:
When a transistor has zero current through it, it is said to be in a state of cutoff (fully nonconducting). [i'd dispute that "cutoff" is occurring when a lead is "floating". (that's in this page's text.) true cutoff happens in reverse bias, doesn't it? maybe a caveat can be offered here. but that's up to you. i see that you don't want to be too technical on this particular page.]
well, anyway, that's my 2 cents.
thanks
john
it should read:
then:
picture caption:
picture caption:
thanks
john
