:mellow:
Can you supply additional details describing how you would like this model elevator operates?Originally posted by rose ann arandia@May 14 2006, 06:30 PM
:mellow:
[post=17084]Quoted post[/post]
it is a two storey elevator system.....runs by a motor,limitting switches and a simple circuit diagram......this is only my plan and honestly i dont know where to start this project.....so pls help me....thank in advance....Originally posted by hgmjr@May 14 2006, 04:40 PM
hgmjr
[post=17085]Quoted post[/post]
Exactly.....can you give me all the name of materials needed in this project....pls....thanks a lot......Originally posted by thingmaker3@May 14 2006, 06:33 PM
Okay, just look at a full scale elevator...
You'll want limit switch for the upper floor lower floor to stop the motor. Additional switches for "close to limit" would be handy to slow the motor down. You'll want limit swithces for door open and door closed. You'll want a safety bumper switch on the door, and also an optical system to check for obstruction. You'll want a call button on each floor. You'll want a floor selection button for both floors. (Why they do that on a two story elevator, I'll never know. Tradtion, I guess.) You'll want buttons to hold the door open and to close the door. You'll want an alarm button and a telephone or intercom. If you want full authenticity, you'll want a key switch for lockout and over-ride.
You'll want logic that determines whether the motor moves, and in which direction. For full authenticity, you can add a fire alarm recall feature. You'll want logic for opening and closing the door.
...unelss, of course, it's just an old-fasioned freight elevator. Then you just need limit switches for each floor and direction control switch. I've been in one elevator where everything was done with one switch, a steel cable, and some clever mechanical bits. We pulled up on the steel cable to go down, down to go up, and the mechanical bits pulle the cable the other way when we got to where we wanted to be and threw a lever.
[post=17098]Quoted post[/post]
You don't need to adjust speed if the problem is faulty landing (the old "watch the step" problem). You can use a electric break to make the motor stop quickly. That is done by shorting the motor terminals after the current is switched off. This would be a simpler and cheaper solution and requires just the same number and type of relays I recommended in my suggestion.Okay, just look at a full scale elevator...
You'll want limit switch for the upper floor lower floor to stop the motor. Additional switches for "close to limit" would be handy to slow the motor down...
True, but the relay contacts would take a while to break/make. In the meantime, quite a large voltage spike would build up across the now-open contacts due to the inductance of the motor. A non-polarized capacitor across the motor terminals would help to blunt this spike; the size of which is TBD.You don't need to adjust speed if the problem is faulty landing (the old "watch the step" problem). You can use a electric break to make the motor stop quickly. That is done by shorting the motor terminals after the current is switched off. This would be a simpler and cheaper solution and requires just the same number and type of relays I recommended in my suggestion.
Indeed, you got a point. But most common relays have double trow contacts, which means that the same contact can be used to turn on the motor and to short the motor.True, but the relay contacts would take a while to break/make. In the meantime, quite a large voltage spike would build up across the now-open contacts due to the inductance of the motor. A non-polarized capacitor across the motor terminals would help to blunt this spike; the size of which is TBD.
Too small = large spike; may exceed voltage rating of cap = destroyed cap.
Too large = excessive current draw on motor start.
L | looking for miniature Audio connector | Datasheets, Manuals & Parts Identification | 6 | |
V | miniature elevator.. need help. | General Electronics Chat | 6 | |
S | circuit design on 220v miniature elevator.. | General Electronics Chat | 1 | |
H | Miniature Elevator | General Electronics Chat | 7 | |
S | elevator miniature | Homework Help | 0 |
