Mini-power transformer ?
Externet
Joined Nov 29, 2005
2,678
Hello.
Guts of 1A USB charger from AC have a minuscule transformer. Where to source such ? Part number ? The adapter accepts "100 to 240VAC" How can such tiny thing work on a quarter kilovolt ?
Re-purposing / canibalizing an adapter just like this, found it is for real, has about a cubic centimetre transformer. Is there any trick to achieve its performance/isolation ?
Hello.
The "100 to 240VAC" AC is rectified to DC. The small transformer is a high frequency switching supply type as per the link provided by @Ian0
28,419
The reason it can be so small is that it is operating at 100kHz or so.
The beauty of using a much higher frequency is that the transformers can be much smaller for a given power level. That is why the surplus avionics goodies all use 400 cycle or even 800 cycle transformers.
