MiCS-4514 Gas Sensor with a FET explanation
Link068
Joined Apr 10, 2017
31
I am planning to use the MiCS sensor in a project, however I am confused my the circuit diagram that has been provided. I have attached the data sheet below.
To my knowledge this device will increase or reduce the voltage on the output depending how much gas is in the air. What I don't understand is why is there a fet after the voltage divide? Couldn't you just have that going straight into a ADC on a MUC?
Also would a mosfet be more suitable?
Cheers,
