Microcontroller GPIO
Abhinavrajan
Joined Aug 7, 2016
83
How much Voltage will be present at the GPIO pin for a Microcontroller which has a Vcc(Input Supply voltage) of 3.3V ?
Suppose I need to connect an LED at this GPIO what are the factors or calculations that I have to consider ?
And, How much voltage should I apply to an LED to turn it on? What should be its supply voltage?
jpanhalt
Joined Jan 18, 2008
11,087
You don't mention which microcontroller you are using. Generally such information about voltage is in the electrical specifications section of the datasheet. If you are talking PIC's, here are data for the 12F509, which has a GPIO port:
Remember that the maximum allowed current from a pin is 25 mA (also in the electrical specifications)
John
hp1729
Joined Nov 23, 2015
2,304
Look at the specs for the microprocessor in question. What is the output voltage. How much current?
Same with the LED. Get a data sheet for that LED and look at what voltage and current are required.
Finding data sheets ... there are a lot of places on the WWW to find data sheets. A personal favorite of mine is www.alldatasheet.com.
22,082
LEDs are current devices not voltage devices. What does that mean? It means you can drive them from any voltage at all, as long as you use a resistor to set the current.
hp1729
Joined Nov 23, 2015
2,304
Basically true. If he only has 3 Volts white, blue, UV and such LEDs are a problem. They all like more than 3 Volts for full brightness.
shteii01
Joined Feb 19, 2010
4,644
3.3V
LED forward voltage.
LED maximum current.
GPIO maximum current.
This information is supplied by manufacturer.
hp1729
Joined Nov 23, 2015
2,304
3.3V
DESIRED LED current. You don't have to run it at maximum. If the GPIO pin can only drive 5 mA you are limited to that, or use a buffer transistor. Can you drive the LED at 2 mA and get sufficient brightness? Try it.
Abhinavrajan
Joined Aug 7, 2016
83
3.3V
Crisp and clear. Thank you.
