RN4020's RX line or your PIC's RX line?The device will not go into sleep if the RX line is low. My code defaulted to a low RX when the EUSART is disabled.
The only one that is always an input.RN4020's RX line or your PIC's RX line?
RN4020's input or your PIC's input?The only one that is always an input.![]()
;** BLTOG -- Toggle Bluetooth on/off **
bltog bbs fbton,bltoff ;turn bluetooth off?
;Turn bluetooth off
blton bsf fbton
return
;Turn bluetooth on
bltoff bcf fbton
return
;** POLLBT -- Bluetooth polling -- called each main loop pass **
pollbt retbc run ;don't process bluetooth until system initialized and running
BANKSEL btstate ;select bluetooth working bank
clrf btsresp,1 ;clear standard response flags
clrf btsresp+1,1
rcall btprcv ;check to see if a new bluetooth response has been received.
bz pbtnrsp ;no response
;a response has been received from bluetooth
movlw b'01111111' ;ignore NWR flag
andwf btswait+1,w,1
iorwf btswait,w,1 ;are we waiting for a particular response?
bz pbstate ;no, just process machine
;decide whether or not to throw an error
bbs fwrerr,pbteok ;is ERR an acceptable response?
bbs fsrerr,pbterr ;No, flag ERR as error.
pbteok bbs FWRNWR,pbstate ;improper responses don't throw errors if NWR bit set
movf btswait,w,1 ;are we waiting for a response?
andwf btsresp,w,1 ;has a proper response been received?
bnz pbstate ;yes, process state machine
movf btswait+1,w,1 ;again, next byte
andwf btsresp+1,w,1
bnz pbstate
bra pbtimp ;flag an improper response
;no response received from bluetooth this pass -- process timed functions
pbtnrsp movf btstime,f,1 ;is timer running?
bz pbtntim ;no, not a timed function
;timed function -- either response time-out or timed state
btfsc tc16ms ;process 16ms timer
decfsz btstime,f,1 ;decrement state timer
bra btx____ ;no further processing if timer not expired
andwf btswait+1,w,1
bz pbstate ;no, just process timed state after delay
;otherwise, flag a timeout error
bra pbtrto ;show timeout error
;not a timed function
pbtntim bbs fwrnwr,pbstate ;don't wait for response if bit is set
movf btswait,w,1 ;are we waiting for a particular response?
iorwf btswait+1,w,1
bz pbstate ;no, just process the untimed state
bra btx____ ;otherwise, just wait until response
;Handle improper response
pbtimp btfsc fsrnsr ;non-standard response?
rcall btpnsr ;go parse it
bra btx____ ;ignore improper responses (for now)
;Handle ERR response
pbterr movlb 0
movlw bterr ;get ERR error code
call seterr ;and show error
bra btx____ ;ignore erroneous responses
;Handle timeout during reception of response
pbtrto movlb 0
movlw btrto ;get time out error code
call seterr ;and set error limp along
;process Bluetooth state machine
pbstate clrf btswait,1 ;clear waiting flags for next pass
clrf btswait+1,1
clrf btstime,1 ;and state timer
movfw btstate
call cjump
;idle with bluetooth off
bra btsid0 ;state 0: idle awaiting BTAWAKE hardware line if bluetooth on
;setup blue tooth
bra btssu0 ;state 1: begin setup, get feature string
bra btssu1 ;state 2: get/set friendly name
bra btssu2 ;state 3: get/set model name
bra btssu3 ;state 4: get/set manufacturers name
bra btssu4 ;state 5: get/set bitmap services
bra btssu5 ;state 6: send LS to confirm private services
bra btssu6 ;state 7: confirm private service UUID is defined
bra btssu7 ;state 8: confirm all private characteristic UUIDs
bra btssu8 ;state 9: scan for end of LS list
bra btssu9 ;state 10: start reset/reboot process -- clear private services
bra btssuA ;state 11: add private services
bra btssuB ;state 12: iteratively add private characteristics then reboot
bra btssuC ;state 13: wait for reboot to complete and redo LS to load handles
bra btsadv ;state 14: start advertising
;active with bluetooth on
bra btsac0 ;state 15: idle for connects/disconnects and monitor monitor for shutdown
;shudown bluetooth
bra btssd0 ;state 16: switch to dormant mode
bra btssd1 ;state 17: clear wakesw and shutdown EUSART
;** Bluetooth states **
;-- State 0: wake BT, await BTAWAKE hardware line, then wait for CMD message
btsid0 bbc fbton,btx____ ;do nothing if bluetooth not activated
call uarton ;turn eusart on
bsf wakesw ;wake bluetooth
bsf wakehw
bcf fbtrbt ;clear reboot flag for setup
bsf fwrcmd ;wait for "CMD"
bra btx__LN ;with a long timeout
;-- State 1: begin setup, get, compare, and set feature string if necessary
btssu0 bbs fsrnsr,btssu01 ;gf data received (as non-standard response?)
btssu00 txpstr sbtgfs ;get feature settings string
bsf fwrnsr ; wait for non-standard response
bra btx__T_ ; wait 200ms and don't advance
btssu01 rxpcstr sbtsfs ;expected value received?
skpnz
bra btx___N ;yes, advance to next state
bsf fbtrbt ;indicate a reboot is going to be required
txpstr sbtsfs ;send feature settings string
bra btx_ATN ;and advance
;-- State 2: get, compare, and set friendly name if necessary
btssu1 bbs fsrnsr,btssu10 ;friendly name received (as non-standard response?)
txpstr sbtgfn ;get friendly name string
bra btx__TR ; wait 200ms for NSR and don't advance
btssu10 rxpcstr sbtsfn ;expected value received?
skpnz
txpstr sbtsfn ;send new friendly name
;-- State 3: get, compare, and set model if necessary
btssu2 bbs fsrnsr,btssu20 ;model received (as non-standard response?)
txpstr sbtgmod ;get friendly name string
btssu20 rxpcstr sbtsmod ;expected value received?
skpnz
txpstr sbtsmod ;send new friendly name
;-- State 4: get, compare, and set msnufacturer's name if necessary
btssu3 bbs fsrnsr,btssu30 ;manufacturer's name received (as non-standard response?)
txpstr sbtgmn ;get manufacturer's name string
btssu30 rxpcstr sbtsmn ;expected value received?
skpnz
txpstr sbtsmn ;send new manufacturer's name
;-- State 5: get, compare, and set bitmap services if necessary
btssu4 bbs fsrnsr,btssu40 ;bitmap services received (as non-standard response?)
txpstr sbtgbms ;get bitmap services string
btssu40 rxpcstr sbtsbms ;expected value received?
skpnz
txpstr sbtsbms ;send new bitmap services
;-- State 6: send LS command to confirm private characteristics set up properly
btssu5 clrf bthctr,1 ;clear handle counter for later
txpstr sbtls ;send ls
bsf fwrnsr ;wait for non-standard response
bsf fwrend ;allow an END if nothing in the list
bra btx__TN ;and advance
;-- State 7: check if the private service is defined
btssu6 bbs fsrend,btrbt ;if END received, list is empty, reset and reboot
rxpcstr sbtsps ;expected value received?
bz btssu60 ;yes, set up for private characteristics
bra btx__TR ;await response for END/NSR and return here
btssu60 bsf fwrnsr ;wait for non-standard response
;-- State 8: iterate to check UUID for each private characteristic -- capture handle if exists
btssu7 bbs fsrend,btssu70 ;if END received, ensure we got all characteristics
movfwb bthctr ;have we exhausted the number of characteristics?
xorlw cnumcar ;compare
bz btssu71 ;yes. Should have been END. Scan to END, reset and reboot.
movlf tblptrl,low sbtsc1 ;tblptr->first characteristic setup string
movlf tblptrh,high sbtsc1
movlw 44 ;43 bytes per private service string
mulwf bthctr,1 ;prod = index into list of strings
movfw prodl ;set tblptr->correct characteristic string
addwf tblptrl,f
clrw
addwfc tblptrh,f
bsf fbtcaph ;indicate we want private characteristic handle captured
call _rxpcstr ;compare string & capture handle
bnz btssu71 ;no, string not matched. Scan to end, reboot and reset
incf bthctr,f,1 ;bump counter for next private characteristic
bra btx__TR ;come back to this state with NSR/END response
; END received -- ensure we captured [cnumcar] characteristics
btssu70 movfwb bthctr ;have we exhausted the number of characteristics?
bnz btrbt ;no. Should have been END. Reset and reboot.
movlfb btstate,cbtsrbt ;all good, but reboot if necessary
bra btx____
; No match. Scan to END, reboot and reset
btssu71 bsf fwrnsr ;wait for non-standard response
bsf fwrend ;wait for END if nothing in the list
;-- State 9: scan for END, reboot and reset
btssu8 bbs fsrend,btrbt ;reset and reboot if END received
;-- State 10: start reset/reboot process if necessary -- clear all private services
btssu9 bbs fbtrbt,btssu90 ;reboot necessary?
movlfb btstate,cbtsadv ;no, start advertising
bra btx____
btrbt movlfb btstate,cbtsrbt ;jump in here. Set to this state.
btssu90 bcf fbtrbt ;clear reboot flag for next pass
txpstr sbtcps ;clear any existing private services/characteristics
;-- State 11: add private services
btssuA clrf bthctr,1 ;preclear handle counter to index private characteristics
txpstr sbtsps ;add private servcie
;-- State 12: iteratively add private characteristics, then, reboot
btssuB movfwb bthctr ;have we exhausted the number of characteristics?
bz btssuB0 ;do actual reboot
;including stupid assembler padding 0
addwf tblptrl,f
clrw
addwfc tblptrh,f
incf bthctr,f,1 ;index to next characteristic
call _txpstr ;transmit string
bra btx_AT_ ;AOK and return here
;all characteristics set. Reboot
btssuB0 txpstr sbtres ;send reset
bsf fwrrbt ;wait for 'Reboot'
bra btx__TN
;-- State 13: wait up to 3,200 ms for reboot sequence -- then go do LS all over again to load handles
btssuC bsf fwrzcmd ;wait for '\0CMD'
movlfb btstate,cbtsls ;set up LS as next state
bra btx__L_ ;long timeout for reset
;-- State 14: start advertisement
btsadv txpstr sbtadv ;send start advertisement
bra btxEATN ; AOK Expected (Error if already advertising)
;-- State 15: active as connected/disconnecedt -- monitor fbton in case bluetooth is to shut down
; and process all characteristic writes,reads,and requests from central device
btsac0 bbs FSRCON,btsac00 ;connect received?
bbs FSRCEND,btsac02 ;disconnect received?
bbc fbton,btsac03 ;bluetooth needs to turn off?
bra btsac01
;connect received
btsac00 bsf fbtconn ;indicate connection
;quit and come back
btsac01 bsf FWRCON ;allow connection response
bsf FWRCEND ;allow connection end response
bsf FWRNSR ;allow non-standard for notifications
bsf FWRNWR ;don't wait for a response
bra btx____ ;and come right back next pass
;disconnect received -- start advertising again for seamless reconnect
btsac02 bcf fbtconn ;indicate connection lost
bra btx_AT_ ;wait for AOK
;shut down gracefully -- stop advertising or kill a connection
btsac03 bbs fbtconn,btsac04 ;connected?
;stop advertising
txpstr sbtkadv ;no, send stop advertise command
bra btxEATN ;and advance (allow error, but shouldn't happen)
btsac04 bcf fbtconn ;killing connection, so clear it
txpstr sbtkill ;send kill command
bsf FWRCEND ;wait for Connection End
bra btxE_TN ;wait for connection end, but allow for error JIC
;-- State 16: put bluetooth into dormant mode
btssd0 bcf wakehw ;pull line low
txpstr sbtdorm ;send dormant command
bra btx__TN ;result will be 0x00, which we cannot parse, so just time it
;-- State 17: shutdown bluetooth and EUSART
btssd1 call uartoff ;turn eusart off
bcf wakesw ;turn off bluetooth uart transmitter
movlfb btstate,cbtsid ;set up idle0 as next state
bra btx____ ;and immediate idle
;***** END OF STATES *********
;**** Various Exits of SM to set up next state, timeouts, and responses ****
; E=ERR A=AOK T=short timeout L=long timeout N=advance to next state R=Allow non-standard response
btxE_TN movlfb btstime,cbtsto ;STO/ERR/NEXT
btxE__N bsf FWRERR ;ERR/NEXT
bra btx___N
btxEATN bsf FWRERR ;ERR/AOK/STO/NEXT
btx_ATN bsf FWRAOK ;AOK/STO/NEXT
btx__TN movlfb btstime,cbtsto ;STO/NEXT
btx___N incf btstate,f,1 ;NEXT
bra btx____
btx__TR bsf FWRNSR ;STO/NSR
bra btx__T_
btxEAT_ bsf FWRERR ;ERR/AOK/STO
btx_AT_ bsf FWRAOK ;AOK/STO
btx__T_ movlfb btstime,cbtsto
bra btx____
btx__LN incf btstate,f,1 ;LTO/NEXT
btx__L_ movlfb btstime,cbtslo ;LTO
btx____ movlb 0 ;nothing
return
;**** END OF SM EXITS ****
;** BTPRCV -- Process Bluetooth receiver**
;** return z if no response **
btprcv movlf fsr1h,high btrcvbuff ;point to receiver buffer
movff btrhead,fsr1l ; and index to next character
btplp rcall rxbyte ;receiver byte available?
retz ; z if none
movwf indf1 ;save character at current position
movlw '\r' ;ignore return characters
cpfseq indf1
movf postinc1,w ;get back in w, and update pointer
movff fsr1l,btrhead ;save new head position
xorlw '\n' ;new character a line feed?
bnz btplp ;no, get some more characters, if available
movlfb btrhead,low btrcvbuff ;reset btrhead for next message
;parse for common messages
;if common response not matched, indicate (likely) parameters returned from RN4020
bsf btsresp,0,1 ;set 1st bit in standard response flags
movdf tblptr,btsmes ;tblptr -> possible standard responses (\n separated, \r terminated)
btplp0 lfsr 0,btrcvbuff ;fsr0 -> point to head of response buffer
btplp1 tblrd *+ ;get next character from list of responses
movlw '\r' ;\r is response list terminating character
xorwf tablat,w ; end of response list?
bz btpnmf ;yes, no response matched
movf tablat,w ;get character
cpfseq postinc0 ;test against charcter in response buffer
bra btpnom ;!= means no match, skip to next response
movlw '\n' ;is it a new line character?
xorwf tablat,w
bz btpmat ;yes, we have found a match
bra btplp1 ;keep testing characters till match
;no match of current response, skip ahead till /n or /r
btpnom clrc ;roll to next response
rlcf btsresp,f,1
rlcf btsresp+1,f,1
btplp2 tblrd *+ ;get next character from list of responses
movlw '\r' ;get terminating character
xorwf tablat,w
bnz btplp2 ;loop till \0 or \n
bra btplp0 ;and test against next response
;match found, response bit set
btpmat
;match not found, non-standard response bit set
btpnmf clrz ;nz indicates a new reponse has been received
return
;** BTPNSR -- Parse Non-Standard Responses **
btpnsr clrf bitcnt ;use bitcnt as index to received response
movdf tblptr,btnsmes ;tblptr -> possible non-standard responses (\n separated, \0 terminated)
btpnlp0 lfsr 0,btrcvbuff ;fsr0 -> point to head of response buffer
btpnlp1 tblrd *+ ;get next character from list of responses
movf tablat,w ;get character from list
bz btpnnf ;z=end of list, not found
movlw '\n' ;== \n means we have a match!
xorwf tablat,w
bz btpnm ;go process for arguments
cpfseq postinc0 ;compare with received
bra btpnnm ;no match, skip to next response
bra btpnlp1 ;continue till match/no match
;no match of current response, skip ahead till /0 or /n
btpnnm incf bitcnt,f ;update response counter
btpnlp2 tblrd *+ ;get next character from list of responses
bz btpnnf ;z=end of list -- no match
xorlw '\n' ;is it a new line character?
bnz btpnlp2 ;loop till \0 or \n
bra btpnlp0 ;and test against next non-standard response
;no match found - what do we do?
btpnnf return ;for now, just ignore the response
;match found -- bit count has response number
btpnm movfw bitcnt ;get response number
call cjump ;and process it
bra btnscp ;'ConnParam:'
bra btnsnfy ;'Notify,'
bra btnsind ;'Indicate,'
bra btnswv ;'WV,'
bra btnswc ;'WC,'
bra btnsrv ;'RV,'
;ConnParam <hex16>,<hex16>,<hex16> (connection interval, slave latency, supervison timeout)
btnscp lfsr 1,conint+1 ;point to holders
rcall hex2bin ;capture interval
rcall hex2bin ;capture slave latency
rcall hex2bin ;capture supervision timeout
return
;other non-standard responses -- for later -- just indicate unhandled for now
;notification received
btnsnfy ;'Notify,'
;indication received
;write value to local server characteristic
btnswv ;'WV,'
;write configuration to local server characteristic
btnswc ;'WC,'
;real time read (bit must be set in supported features (SR)
btnsrv ;'RV,'
bra btpnnf ;indicate unhandled non-standard response
;** HEX2BIN -- Convert arbitrary length hex to binary **
;** store result at fsr1 -> RAM (high byte) **
;** ignore spaces, comma or \n terminated **
;** target RAM must be large enough to hold expected value **
hex2bin
;process high byte first
movf postinc0,w ;get next character
sublw '\n' ;is it a newline?
retz ;yes, we are done
addlw 22 ;is it a space?
bz hex2bin ;yes, ignore it
addlw 12 ;is it a comma?
sublw -14 ;'A'-'F' = 7-12, '0'-'9' = -10 - -1
skpc ;correct for 0-9
addlw 7 ;'0'-'9' = -3 - 6
addlw 3 ;final result
swapf wreg,f ;swap for high byte
movwf indf1 ;and save
;then low byte (no need to check for terminators on odd characters)
h2b1 movlw 58
subwf postinc0,w ;'A'-'F' = 7 - 12, '0'-'9' = -10 - -1
iorwf postdec1,f ;merge in
bra hex2bin ;do for all characters
;** RXPCSTR -- Compare received string with program memory **
;** program memory string terminated with \r **
;** tblptr -> string **
;** ignore leading characters in PM until first comma **
;** ignore leading spaces in RAM **
;** z if match, nz if no match **
;** if fbtcaph is set, handle for char #(bthctr) is captured **
_rxpcstr
lfsr 0,btrcvbuff ;point to bluetooth receive buffer
movlw ',' ;skip to character after first comma
rxpclp0 tblrd *+
cpfseq tablat
bra rxpclp0
rxpclp1 movlw ' ' ;ignore leading spaces in RAM
xorwf postinc0,w
bz rxpclp1
movf postdec0,w ;move pointer back to first non-space character
rxpclp2 tblrd *+ ;get character from program memory
movlw '\r' ;terminates with /r
xorwf tablat,w ;compare
retz ;return with z to indicate match
bbc fbtcaph,rxpcb0 ;capture handle flag set?
movlw ',' ;handle starts at first comma
xorwf indf0,w ;compare
skpnz
rcall rxpch ;go capture handle
rxpcb0 movf indf0,w
movfw tablat ;get pm character
xorwf postinc0,w ;compare with received character
bz rxpclp2 ;match, keep going
return ;return with no match
;capture handle at current ram position +1
rxpch bcf fbtcaph ;clear capture flag for any remaining commas
lfsr 1,hpchar1 ;fsr1->start of characteristic handle table
rlncf bthctr,w,1 ; *4 (size of handle)
rlncf wreg,w
addwf fsr1l,f ;fsr1->proper handle
movff preinc0,postinc1 ;copy 4 bytes
movf postinc0,f ;index to tailing comma
return ;and go finish scan
include "btcb.asm" ;include custom callbacks to main program
include "btstrings.asm" ;include command/response strings
What size of battery will your device be using?This is a battery operated device. Here are the measured currents in various modes in the order I recorded them:
Upon inserting the battery: 54 uA
Power on, Bluetooth off: 15.9 mA
Power on, Bluetooth on, advertising: 18.3 mA
Power on, Bluetooth on, connected: 18.1 mA
Power on, Bluetooth on, disconnected, advertising: 18.3 mA
Power off: 54 uA.
Cool.
The answer is irrelevant, considering this thread is about the RN4020 and not my product.What size of battery will your device be using?
Maybe I should've stated my question as follows:The answer is irrelevant, considering this thread is about the RN4020 and not my product.
What's important is that the RN4020 consumes a bit more than 2mA when active, and less than 1uA in dormant mode. The larger numbers you see are the combination of the RN4020 and my product's base current requirements.
It may still be listening to UART. The doc says it'll respond to UART in deep sleep mode if baud rate is 2400, but it doesn't say what happens at other baud rates. If UART is still on, then when you drop your TX low, RN4020 sees it as a start bit. So it just immediately wakes up.Setting the RX pin of the RN4020 was only half the picture. This only got me into deep sleep, not dormant.
The docs for RN4020 are really bad in this respect. They say very little, and what they do say is confusing. Congratulations on figuring that out!To go dormant is a lot more complicated and completely undocumented.
Zero defects, zero errors.
Quite a few, though I don't count them. I did work solid through the memorial day weekend -- like 6AM through midnight each day.how many hours did you put into this project?
Exactly.Time only matters when your doing something you don't like.
And what was the proportional amount of work between coding and designing the electronic hardware/interface?Coding *definitely* is not the majority of the time. The biggest time sink was the bad documentation for the RN4020. And I do lots and lots of testing of small bits of code. The code has to be absolutely robust, so I do only small amounts between tests to be sure that *every possible* contingency is covered.
This is a drop-in addition to an existing product. There was no actual design time. But I did have to sticky-tape the the RN4020 to the existing PCB and run some wires between the MCU and the RN4020. The MCU is an 80 pin PLCC -- so the (wirewrap) wires had to be soldered under a microscope. About an hour of time for the total (prototype) assembly. For production, I'll have a new PCB with the RN4020 footprints, obviously.And what was the proportional amount of work between coding and designing the electronic hardware/interface?
And you'll be in charge of designing that too? And since it's an addition for an existing product, will it affect its casing/container ... I am guessing that after some point another department will be taking care of that, right?For production, I'll have a new PCB with the RN4020 footprints, obviously.
I just change hats and hang a different sign on my door.And you'll be in charge of designing that too? And since it's an addition for an existing product, will it affect its casing/container ... I am guessing that after some point another department will be taking care of that, right?
Well congrats, man. It's not everyday that one gets to accomplish something of this level. From what you've described, this qualifies as a milestone in your professional (and possibly also personal) life. Thanks for sharing.I just change hats and hang a different sign on my door.
I say this ever so humbly: I accomplish this, and more, every day of my life. I've said here once before: I do at least three impossible things every day. But the feeling of accomplishment never get old. And the harder the effort, the better it feels at the end.Well congrats, man. It's not everyday that one gets to accomplish something of this level. From what you've described, this qualifies as a milestone in your professional (and possibly also personal) life.
| Thread starter | Similar threads | Forum | Replies | Date |
| P | Microchip MCC not usable | Programming & Languages | 16 |
| Similar threads |
