Method to switch between two loads in simple AC circuit?
Ya’akov
Joined Jan 27, 2019
10,295
But what might be the simplest circuit you could envision for this purpose, it might still be within my abilities.
Given your constraints, and the fact that it is a noisy AC signal, the only thing that occurs to me is to use a high frequency signal from the trailer light to operate a switch at the bike light. If it is present, switch off; otherwise behave NC.
This is "simple" but not in the sense you mean.
dohnjoe
Joined Apr 14, 2021
11
So I thought about it. And here would be my idea. Mosfet P to switch the first lamp. Would this work, and if so, what would I need to take into account (resistors and capacitor wise).
Thanks in advance.
AlbertHall
Joined Jun 4, 2014
12,653
Without looking too deeply, the top right diode of the bridge is connected directly across the generator output so it will short out the negative half cycle.
click_here
Joined Sep 22, 2020
548
My first thought is to use relays - i.e. When current goes through one loop, open the other, when the current through the first loop stops (opens connector) the other loop closes
AlbertHall
Joined Jun 4, 2014
12,653
The relay coil is in series the lamp so they must share the voltage and there is only 6V available and the lamp needs that. You would need a very special relay to do opertae but leave most of the voltage for the lamp.
