Method to switch between two loads in simple AC circuit?
dohnjoe
Joined Apr 14, 2021
11
So I have lost all my knowledge of circuitry apparently and need some help.
I have a small bicycle lighting project: I have a lamp that is attached to an AC generator, producing between 1 and 10 V, and would like to attach a second lamp in parallel to the first. When this second lamp is turned on I would like the first one to go out (without a switch). Is there any simple method out there to do this...Triac, diode...etc. ?
Thanks in advance,
Dave
djsfantasi
Joined Apr 11, 2010
9,189
Thanks in advance,
Dave
How do you turn on the second lamp?
dohnjoe
Joined Apr 14, 2021
11
It's actuallly a lamp on the trailer, and I would be attaching it to the bike in parallel to the first ligth (rear) in parallel. I would like the first one to turn off after attaching the second one. Not sure this is even possible without something complexer than I'm willing to build. Would like no switches at all. SO that's why I was thinking a triac or something, and source is a AC.
dohnjoe
Joined Apr 14, 2021
11
Something like 0.2 Watt at 6 Volt, can vary around that and be up to 0.6 Watt, depends on speed and the circuitry of the LED Lamp.
AlbertHall
Joined Jun 4, 2014
12,407
You want the main light to turn off when the trailer is plugged in?
One way to do that would be to have a plug/socket with an extra pin. Then you have an extra plug with a link between the power and this extra pin and the main light is connected to the extra pin. When this second plug is plugged in the main light gets its power via the link on the plug. When that plug is removed and the trailer plug, which doesn't have that link, is plugged in the main light power is disconnected. Thus the switching is automatic.
dohnjoe
Joined Apr 14, 2021
11
Thought of this, but would like to use a 2-pin pogo magnet connection. And if there is no simple solution would probably go this route. For me the problem with that is that the female plug is in the elements and exposed to dirt/grime/rain, and will eventually corrode on the inside.
dohnjoe
Joined Apr 14, 2021
11
Water would likely still get in through the socket unless I had an extra pug for that. Thanks for the tip. Still looking to see if there might be an electronic solution. And if that fails, like I said I'd likely go the plug/socket route. Thanks for your help.
Ramussons
Joined May 3, 2013
1,423
Whatever "electronic" solution you work out, you are going to have an electric connector to feed the trailer. That is going to be a metal contact which takes you back to post #9.
dohnjoe
Joined Apr 14, 2021
11
Not if it's gold plated. And surface corrosion isn't the problem, it's the problem of a closed space and the corrosion taking place there
dohnjoe
Joined Apr 14, 2021
11
Thanks for all the tips, but I'm still looking for a solution to the original question and not a physical work-a-round. Anybody got an idea?
dohnjoe
Joined Apr 14, 2021
11
But what might be the simplest circuit you could envision for this purpose, it might still be within my abilities.
