Metal Halide Lighting Circuit Issues
ab6014
Joined Jan 4, 2018
The background: I'm building a rig for an engineering project to age polymers, using UV radiation and water cycles. The power supply, water pump and actuator (use not relevant) are controlled via an Arduino.
The rig has worked in the past with Infrared bulbs (for a different project). I'm now switching to UV bulbs which require ballast and ignitor to run.
The problem: I wired up one bulb to begin with, the bulb turned on but after I turned the circuit off, the power tripped (large circuit breaker for the entire run of sockets in the laboratory).
Second attempt, checked the wiring and wired up both lamps in series. This time the bulbs did not turn on, but the power tripped again.
Ballast Link: https://uk.rs-online.com/web/p/lighting-ballasts/7840515/
Ignitor Link: https://uk.rs-online.com/web/p/lighting-ignitors/6677268/
UV Bulb Link: https://uk.rs-online.com/web/p/uv-curing-lamps/8298870/
Circuit diagrams for series and single bulbs respectively:
The only issue I can think of causing the trip is that I'm yet to properly earth the circuit. Similarly for the two bulbs not operating at all, I'd guess it was a more fundamental issue with running the lamps in parallel as shown, I've not seen a diagram online like this, I simply assumed it would be okay.
Thanks in advance, Adam
ab6014
Joined Jan 4, 2018
Ah, I cant remember why I decided I didn't need the capacitor, seems stupid now. I cannot see on the ballast what the required size is however. upload_2018-1-4_13-28-56.png
Still not sure why it would start with one bulb and not the second however?
ab6014
Joined Jan 4, 2018
Ah of course! Thanks a lot.
Any idea why the bulbs would not turn on when in parallel as per my diagram? The capacitor shouldn't affect them starting
be80be
Joined Jul 5, 2008
2,395
There are 2 kinds of bulbs probe-start and pulse start
The pulse-start need a starter The probe-start don't and if you put them in a pulse-start setup you need a new
bulb they never fire agin. But the bulb shows it to be a pulse start
This starter is not good for that bulb it's 400 watt you have 460 watt bulb.
