Mesure the current needed for motor to handle certain weight
kamel2913
Joined Mar 6, 2015
43
Hi guys,
So I want to turn an acutator that weight 74 g with my stepper motor (5v) and easyDriver Motor driver, I want to know how much current need for this, and what equation to use to can know the current needed for certain weight.
WBahn
Joined Mar 31, 2012
33,002
Depends on all kinds of things that you haven't mentioned. First, what does it mean to "turn" and actuator that weighs 74 g? How does the weight get converted to a load on the motor if you are turning it? How fast is the actuator moving? How fast is it accelerating? What are the specs on the stepper motor?
MaxHeadRoom
Joined Jul 18, 2013
30,728
One basic test is to use a pulley etc of known dia and use a simple spring scale with string wound around the pulley and detect what is the break-away torque is (ft-lbs etc), required to move or rotate the load, this will be a starting point for the Torque value required of the motor.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,728
??But he will need a motor capable of handling the required Load!
If the current required is needed, it will be the rated plate current of the motor and should not be exceeded.
Max.
Picbuster
Joined Dec 2, 2013
1,059
Hi guys,
You should look at the power needed.
75kg in one second one meter high needs 736Watt.
scale this all back to 74Gram and specific actuator variable.
the current needed (loss factor) x watt/volt take 1.2 as loss factor.
that's all
Picbuster
Colin55
Joined Aug 27, 2015
519
There is no such weight as 74g
You have not said if a gearbox is available.
You have not provided any metrics AT ALL.
Nothing can be determined from the information you have provided.
