Mechanical Bull Control Box Issues.
28,392
The mechanical bulls that I have met used two motors, the spin motor was a high powered reverse-able servo motor, the buck motor was a simple high power servo motor that always returned to the same spot.
So my very first suggestion is to inspect the connection cable for damage and shorted circuits.
But if it starts to smoke before any commands are made, the problem is more likely in the power supply portion.
It may also be that somebody poured a beverage into the vent opening of the control box.
