Hi.
Inserting a pex water pipe down the well will be caught everywhere unless it is secured to the wiring or outlet pipe all the way, because it never stays straight.
A few methods:
-Fisk tank vinyl hose secured to the wiring all the way down, and a manometer on surface, like clotheswasher level sensing.
-A pressure sensor by the pump motor and secured wiring to the surface. There is waterproof sensors as ---->http://www.automation.com/images/news/2009/September/honeywell914092_(250_x_200).jpg
Automobiles use them for measuring the manifold pressure, and cheap.
-Measuring motor current on several digits can give a clue of how much water column is there. Pump will work less effort with higher levels.
Has the ongoing drought changed the well reserve level, or is it precaution ?
A few methods:
