Measuring the frequency
Rufinus
Joined Apr 29, 2020
323
Hello. I´m learning english, excuse me if I make mistakes.
I´m building this flyback driver (I know this is dangerous, even lethal, and I´m being careful). I have 2 questions.
There are 2 power supplie. The 12-16V to run the oscillator and the 15-30V to run the flyback.
If I connect everything toguether inside the red square, the power supplies will be in parallel. I´m not sure if the terminal/ground with the blue cross have to be connected with the others. Obviusly the ground of the HV out doesn´t have to be conectes with the others gorunds, I think. So the
The other question is. If I run the oscllator without connecting the mosfet, Will I be able to measure the frequency with my multimmeter?
Thank you.
Kind regards
BillB3857
Joined Feb 28, 2009
2,573
The grounds should be no problem for you, BUT, you need to remove the wire that is shown above pin 4 of the 555 going over to the 15-30V supply. As shown, the two power supplies are connected together. Disconnect the 15-30V supply from the primary of your transformer and measure the frequency. Also, you can find calculator on the internet that will tell you the frequency of your 555 oscillator based upon the resistor/capacitor values you input. Here is only one example:
https://daycounter.com/Calculators/NE555-Calculator.phtml
Rufinus
Joined Apr 29, 2020
323
I think I have done something wrong.
When I connect a 12V 1A power supply to the oscillator, I see a smal spark and if I connect de multimmeter in the gate and source at the begining shows diferent values between 2 and 100 hz, and a few seconds later, goes 0.
atferrari
Joined Jan 6, 2004
5,022
No matter how sure you feel now of doing things right, please post the circuit that you are currently following, supposed to be correct.
Rufinus
Joined Apr 29, 2020
323
Please, don´t kill me, I´m a benniger in electronics and also drawing is not my best skill.
The circuit
My interpretation over the PCB
I don´t show the MOSFET because is not relevant to measuring the frecuency
The result
Rufinus
Joined Apr 29, 2020
323
I´m not sure about useing the calculator. If I want lower frequencies, What resistor should I change? For example to set the minimun frequency about 2 or 3 Khz
DickCappels
Joined Aug 21, 2008
10,662
You should probably change the setting of the wiper on the potentiometer. The output voltage of a flyback converter are highly dependent upon the gate drive duty cycle and input power supply voltage. The the schematic will allow you to use the potentiometer to vary frequency and duty cycle at once.
You can change the frequency range and maintain the range of duty cycle, percentage wise, by changing the capacitor. If you want the frequency range to go down to 3 kHz and the range is now 10 kHz change the capacitor 10/3 times the value of the existing capacitor (which is not shown on your schematic).
Rufinus
Joined Apr 29, 2020
323
Yes, but with the potenciometer, the frequency goes from 10 Khz to 33khz
DickCappels
Joined Aug 21, 2008
10,662
I don't see timing capacitor in your wiring diagram but going by the schematic it is the
capacitor that is connected to pins 6 and 2 of the NE555.
Rufinus
Joined Apr 29, 2020
323
