Measuring current in 3 phase motor with shunt resistor.
Nathan Hale
Joined Oct 28, 2011
159
Hello all and hope all is well.
I would like to measure the current draw in a toy 3 phase AC motor.
I am using a 1 mOhms shunt resistor.
To measure the current, I will have the resistor in series with one of the phases and then measure the voltage across the resistor.
Later, using Ohms law, I will figure out the current draw.
Am I on the correct path to perform this test?
Any feedback will be appreciated.
Thanks for your replies!
MaxHeadRoom
Joined Jul 18, 2013
30,837
At some point before the 3ph, there will be a DC supply to the motor controller, maybe easier just to measure this current, insert a ammeter in the DC line.
Max.
Nathan Hale
Joined Oct 28, 2011
159
Max.
Thanks for your reply. Will the reading be accurate enough at that point you mentioned? What percentage of error can I expect, if any?
Nathan Hale
Joined Oct 28, 2011
159
It depends exactly what you need to know. Are you interested in the power delivered to the motor? The power taken from the power supply? And how accurate do you need?
Looking to figure out the operational current being drawn by the motor.
schmitt trigger
Joined Jul 12, 2010
2,252
Obviously the most accurate method is to measure the actual AC current drawn by the individual phases.
It is also the most challenging, because it would require isolated supplies for each sampling circuit.
If you used a hall-cell based sensor or a current transformer instead of a resistor, the circuit would be significantly simplified.
Why the resistor requirement?
MaxHeadRoom
Joined Jul 18, 2013
30,837
Just measure the DC supply with no motor command to get the consumption of the drive control itself, then subtract this from any reading that includes motion control.
Simple DC ammeter.
Max.
BobaMosfet
Joined Jul 1, 2009
2,211
If you provide a photo of the motor and any part/mfg information, likely a datasheet can be found.
kaindub
Joined Oct 28, 2019
187
Just measuring the AC current of the motor tells you very little. You need to also measure the AC voltage to the motor and the phase angle between the voltage and current. That requires a hell of a lot of computing power and speed.
As someone suggested the simplest and resonably accurate way is to measure the DC current and DC voltage before the motor controller. INA219 chip will do it
MaxHeadRoom
Joined Jul 18, 2013
30,837
Keep in mind this is a toy motor and most likely as in RC versions, it would be a BLDC, not 3ph AC.
Although 3ph AC and BLDC being identical in appearance and construction.
Max.
