MC2100 Rev B- Odd failure
RScandura89
Joined Jan 28, 2023
Hello, first time post here.
I have an MC2100 REV B that works fine without a load (walking) and then when you step on it, it will be fine for about 10-15 seconds and then stop. If I pull my feet back off and rest it on the sides, it will start back up. It’s an odd failure I have seen twice now and I wasn’t sure if anyone had experience with this.
Back history on this board: it had a shorted N channel FET and has been replaced. The driver IC is also new and SCR. It has new electrolytic caps.
Any help would be greatly appreciated!
-Ryan-
MaxHeadRoom
Joined Jul 18, 2013
30,887
Sounds like it is sensing overload, friction of some kind , maybe?
Check the link from motor to belt for any needed lubrication etc.
RScandura89
Joined Jan 28, 2023
I was thinking the same thing but when I switch it with a different MC2100 it doesn’t produce the same issue. I will trying lubricating the deck and checking for any excess drag then try again.
