I need matlab code for the program.program will take binary coded signal like [0 1 1 0] then convert this signal to digital signal by encoder.after signal is modulated the program adds noise to the signal.Signal+noise is demodulated then converted to binary coded signal by decoder.The program should adjust the noise level.At the end, the program should compare the input binary code and output binary code for any errors.But I can't write the code in Matlab.I don't have enough knowledge.Can you help me?
Or just takes the binary coded signal,puts noise then filters it.The output is the detected signal which is a binary signal too.For low noise levels the input and output signals are same.But at high noise, error will occur in detected signal.The program should compare the output and input signals..
Thanks for your concern have a nice day...
