Mathcad and DOSbox
Sparky49
Joined Jul 16, 2011
833
Hi everyone.
I have recently bought a book which comes with a floppy disk with files for "Mathcad 2.5 or higher".
Now, I think that 2.5 can only run on DOS, so would DOSbox do?
I am not quite sure how it works - will I be able to install Mathcad onto the DOSbox ?
I have a windows 7 os.
Thanks,
Sparky
Sparky49
Joined Jul 16, 2011
833
Well, I've managed to get it working - kind of...
Th program loads, but the text is mangled.
This is strange as the help menu is fine.
what could this be?
t06afre
Joined May 11, 2009
5,934
It could be your graphics card settings. I have run quite complex games in Dosbox without any problems. If I remember correct the default setting for graphic card emulation in Dosbox will often give problems. Take a look here and do some experiment on the machine = "settings" start with trying the svga_s3 option
http://www.dosbox.com/wiki/Configuration:DOSBox
nerdegutta
Joined Dec 15, 2009
2,689
The old DOS (Disk Operation System) used some files that automatically loaded some system settings. Autoexec.bat and Config.sys.
I remember that my old config.sys settings had some keyboard settings. Could it be that you need to configure Dosbox?
device = keyboard.sys
It was also some language settings....
panic mode
Joined Oct 10, 2011
5,129
yep, it would load CP (code page) for language of choice. but it also could be that your copy of program is corrupt (MCAD but also DosBox). floppies are not the most reliable way to store data.
i just tried this one (it is only a demo, not sure what the limitations) and it works fine:
http://archives.math.utk.edu/software/msdos/linear.algebra/mathcad/.html
but do you have to use this software? why not just go with wolfram? does much more than MCAD and shows step by step solutions (free registration required).
http://www.wolframalpha.com/
for example
http://www.wolframalpha.com/input/?i=y=2x^2+8x-9
http://www.wolframalpha.com/input/?i=y=e^x+ln(3x)-5
http://www.wolframalpha.com/input/?i=differentiate+x^3-sqrt(x^3+111)-ln((1/x+1))
http://www.wolframalpha.com/input/?i=factor+x^7-8x^6+3x^2-11x+120
http://www.wolframalpha.com/input/?i=integrate+x^2-5x+10-sin(x+pi/4)
http://www.wolframalpha.com/input/?i=y"+5y'-4y=0.5*cos(x)-8
Sparky49
Joined Jul 16, 2011
833
Thanks,
I would go with wolfram, but I don't know the programs within the floppy. It is part of the course within the book, so I thought it would be worth using it.
panic mode
Joined Oct 10, 2011
5,129
according to google Mathcad 2.5 is abandonware and can be obtained from
http://vetusware.com/download/Mathcad 2.5/?id=3430
which only requires free registration.
30 seconds later full version of Mathcad 2.5 is on my computer:
http://www.use.com/ddc2e818959f0d7d426c
It runs and everything is readable. If it runs for you too, then you know that file or two in your copy from the floppy was corrupt.
Btw, they also have Mathcad Plus 5.0 as a Windows version
http://vetusware.com/download/Mathcad PLUS 5.0/?id=74
