Main circuit breaker outside of the main panel ?
Externet
Joined Nov 29, 2005
2,681
Hi.
Is such allowed in USA building/electrical code for residential 230VAC split phase, AC, 60Hz ?
Utility pole------------>Utility energy meter------------->External main breaker, 200A-------------->breaker panel rails----------->circuit breakers---------->circuits
What's the possible problem with this configuration? External 2 pole line 200A feed breakers are common.
https://www.homedepot.com/p/Square-...with-QOM2200VH-Breaker-QOM2E2200NRB/100210055
The Square D by Schneider Electric QO 200 Amp Outdoor Circuit Breaker Enclosure includes a two-pole QOM2 frame sizes circuit breakers 100-225 amp capacity for use as an exterior disconnect. This breaker box is suitable for use as service entrance equipment for compliance up to 2017 NEC code, and is rated Type-3R for outdoor use. This enclosure accepts a B-Hub for top feed applications (sold separately). For non-service entrance equipment applications, ground bar PKOGTA-2 is included.
LowQCab
Joined Nov 6, 2012
5,102
As far as safety goes, it should be fine.
BUT.
The NEC ( National-Electrical-Code ) may not allow any uses that the
Equipment is not explicitly approved, or rated for.
Externet
Joined Nov 29, 2005
2,681
Sure but why if a mains breaker disconnect breaker is already in the typical indoor main breaker load-center box.
Because a non-utility second energy meter will be added to the dwelling apart from the photovoltaic inverter circuitry and existing net-metering.
