Magnetron
ben sorenson
Joined Feb 28, 2022
181
I was curious if magnetrons are "limited" to microwaves, or a specific "bandwidth " or would they allow for higher frequencys such as xrays, etc?
ZCochran98
Joined Jul 24, 2018
356
Well, the frequency at which they operate is largely dependent on the geometry, so, in theory, no, they're not limited to microwaves. However, they'd have to be pretty small to generate anything higher (I don't have a dimension off the top of my head). With reduced size would then also come reduced power capability. For higher frequencies like xrays there are better ways of generating them (such as electron beam collisions or certain materials that just...emit them).
38,703
Whatever the operating frequency range of available magnetrons is, is likely the practical limit of the device, and no, that doesn't extent to x-ray frequencies which are way above that.
The inner magnetron inner dimensions are comparable to the wavelength of the frequency generated, which for a microwave oven is about 12.2 cm with a frequency of 2.45 GHz.
Xrays have a frequency of 10^16 to 10^20 Hz with a corresponding wavelength of 10^-6 to 10^-10 cm, which is obviously far too small to make a magnetron.
ZCochran98
Joined Jul 24, 2018
356
For perspective, 10^-8 cm is 1 Angstrom, or, roughly, the diameter of a hydrogen atom in its ground state.
