magic electromagnet problem
dougalere
Joined Mar 4, 2015
128
hi.
finally got round to 'finishing' this pick up /drop project, works well apart from the fact that the electromagnet does not release when the power is turned off due to residual magnetism.
i have got it to release by desensitising the poles with a bit of insulting tape but this is not entirely ideal.
i am thinking of reversing the coil polarity at release somehow?
any suggestions appreciated.
thank you
dougal
dougalere
Joined Mar 4, 2015
128
hi
i have revised slightly, the coil is now at the collector,the base resistor has been replaced with a 1ok pot.
IC2 is an op amp.
thnk you
doug
dougalere
Joined Mar 4, 2015
128
supply voltage is 4.5 volts, 9volt was found to be too high causing overheating
L1 THE ELECTROMAGNET IS LABELLED as 1 henry, this is a typo.
the transistor is a TIP 31
current around 500 ma
Ramussons
Joined May 3, 2013
1,572
Try a 100 uF capacitor across the electromagnet. When the transistor cuts off, the resultant oscillation of the capacitor-inductance will demagnetise the electromagnet.
dougalere
Joined Mar 4, 2015
128
thank you
i think this is solved in a roundabout way, i am using this to pick up a small nut and bolt -the holding force was fairly close to the residual force, by turning up the holding force and using a heavier nut and bolt it works perfectly, so i guess im swamping the residual force.
30,807
You are probably swamping the residual force by using a reverse polarity, but you may reach the point where the residual is now reversed which then returns to the same problem?
