LTspice Transient Analysis is Stuck
38,859
Changing the SPICE Integration Method from "modified trap" to "Gear" can help to reduce hangups.
Another trick is to reduce the SPICE accuracy tolerances by a factor of 10 for all the simulation parameters (right column below).
That will, of course, reduce the accuracy of the simulation, but that is probably not a problem with this circuit.
