One I/V value does not and LED make...I was wondering if there is a way to change parameters of NSCW100 LED in LTSPice? I like the Vf of 3.5 but would like a max current 180mA for the LED instead of 80mA I believe.
Ya you are right, looking at it now I also got the wrong Vf was thinking of another LED that I looked at. Probably need something more like the pictureOne I/V value does not and LED make...
The usual practice is to find the LED datasheet for the LED you intend to use and match the If-Vf curve.
current flow and voltage node readings, along with the drop of voltage possibly as it goes down the string. This is from a power supply that is 29.5Volts. The CCR is set to 97mA which I just used a source since the ORCAD model of IS32LT3177 just kept crashing.Hi guy,
What are you trying to measure with this simulation?
E
You can configure it as post #8 but replace R1 with a current source of 97m.Was wondering if I also have the string set up correctly? Need to see the Vf at the bottom node. Thanks
