LTS XVII zener.lib
SamR
Joined Mar 19, 2019
5,491
Trying to use a 1N4740A Zener model
and getting a could not open error. So searched and found it and tried to read it and
This is not a Bordodynov file and it is NOT a LTS file? Where the heck is it from?
SamR
Joined Mar 19, 2019
5,491
Peeking in his zip file he has this, so it looks like I need to update my lib
And within it, there is the 1N4030A so it looks like I need to redo my lib files or at least add this.
Bordodynov
Joined May 20, 2015
3,431
Zener_DiodesInc.lib and zener.lib these files contain errors (wrong models). This is the fault of the model developers. I stumbled on this and some models I corrected. But it takes a lot of work to fix (and even test) all the models. So I gave up trying to fix the models. Especially I don't like this model structure.
Papabravo
Joined Feb 24, 2006
22,083
Good to know.
SamR
Joined Mar 19, 2019
5,491
Is this about what you expected? It does not look quite right.
I was going to try and look at how it reacted between Iz(knee) and Iz(max) as I played around with Vs and the R limiter value. Guess I'll have to burn up a few diodes the old fashioned way...
