LTC3863
Berzin
Joined Dec 17, 2020
59
Hi guys actually I am trying something new
I required your help in this systematic of this ic LTC3863 which produce the output of -5 volts so what to change in this systematic in order to get -12 volts
The positive current is coming from IC 555 to transistor to a 12 volt relay which act as a input for the LTC3863 the output is going to get connected to a machine and I can't change the terminal of power or directly attach the positive and ground as I want get it out of the box way and not by any common way
The machine uses 12 volts dc power
38,946
From the data sheet (they are so informative) below:
From that you can calculate the value of RFB1, RFB2, and CFB2 to get -12V.
