What does the Vout (Output Swing) Indicate for this IC? For example, if I have +/- 5V power rails and as an input to the opamp having a range of 5 V pp from the function generator, will the output voltage of the opamp also have 5Vpp as well? Is this IC a rails to rails IC?
