I'm sure this is a pretty simple problem for most on these forums, but I'm having some trouble figuring out the correct sizing, etc. Basically what I want to do is run a particular heating element with a 12 volt DC power supply. To get the proper temperature, I used a variable power supply and found that 3.8 volts @ 7.5 amps gives the desired result. What I want to do is use a simple, cheap method (resistors) to lower the voltage at the heating element to the desired 3.8 volts using a 12 volt power supply since the element will be run off a car battery since I do not want to tote around a 40 lb. Variac when I want to use it. I'm having trouble with two things: 1)what exact value resistors I would need and where to place them in the circuit and 2)if there is any way I can wire it so the resistors do not get overly hot since from, from what I understand, dropping the voltage so much will require a lot of heat dissipation. Any help/alternate suggestions would be greatly appreciated....
