A bit in your case is the same as the value of 1 LSB from your ADC. If your ADC is configured to measure 0-5 volt each bit will have a value equal 5(volt)/(2^8) or approx 19.5 mV pr bit. So your signal shows quite small fluctuationscircle is the marker in matlab plot function. denotes the points where samples are available. in the picture 2 posts above you can see its 256 levels between 0-5V for the 8bit adc. input signal is from laptop speaker out possibly max upto 3V. Sine wave generated with soundcard scope program
"Because in your recording you have values varying only a few bits +/-.." what does that mean?
by Duane Benson
by Aaron Carman
by Jake Hertz
