I'm trying to make a low voltage detector similar to this one with whatever parts I have on hand. Instead of 47K resistors, I tried 56K resistors, and I used 2N3904 in place of C945 NPN's and for the diode I used 1N5231 zener. I begin to think I burnt some 2N3904's because with a 9V battery the lights seem to work properly at first then when I disconnected the battery and tried again, the lights did not work correctly. Sometimes, they both went on when only one should. Then I was reading up datasheets on 2N2222 and 2N3904 that the max voltage for the BE junction is 6V, so I wondered if the transistors are faulty due to 9V being fed into the base. If so, then what transistors that are commonly available should I use in place of then 2N3904 and 2N2222 that can handle higher voltages?
