Loss calculation in a switching Regulator rms current vs Avg Current
hoyyoth
Joined Mar 21, 2020
531
Dear Team
I was going through this video which explains the losses in a switching regulator(Basic Buck Converter). In this the author is calculating only resistive losses and diode losses.
For calculating resistive losses he is considering RMS current through the resistor and for calculating diode losses average current is taken to consideration.May I know why is it so.
How to decide when to consider average current and when to consider the average current.
Regards
HARI
38,946
If the voltage drop is an ohmic resistance (linear with current) then you use RMS current, since the power proportional to the square of the current (RMS is the square-root of the sum of the squares).
If the voltage drop is essentially constant (such as a diode) then you use average current, since the power is proportional to the current.
Edits in Italics:
hoyyoth
Joined Mar 21, 2020
531
Edits in Italics:
Hi Curt,
Thank you.
If we have a constant voltage source and need to find the power across it always use average current.Correct me If I am wrong.
For any linear device we can use RMS current.If I need to find the loss due to MOSFET Rds then I need to use RMS current.
Hope my understanding is correct.
Regards
HAri
vanderghast
Joined Jun 14, 2018
70
The general loss in a MOSFET is more complicated.
For low frequency, you are right, when the MOSFET is blocking, then the current is zero and the power, still current times voltage, is zero. And when the MOSFET is conducting, it is the difference of voltage between the drain and the source, generally called the voltage at the MOSFET, times IC which matters. So, you are rigth using the avarage.
But at high frequency, when you often switches from passing to blocking, your MOSFET come from (low voltage, high current) to (high voltage, low current), in a non zero time. If you draw, on the same graph, versus time (horizontally), both the current and the voltage (vertically), that makes an X. And the product of the two is NOT zero. Each times you switches ON to OFF or OFF to ON, that relatively small loss is repeated. And that may become the MAJOR source of loss if you do it 1000 times, 10 000 times, or 1 000 000 times a second. It is dependant of the switching time, and generally, the datasheet supplies a graph for it, versus the frequency (and the duty cycle, if they add both "types" of loss).
