I am just resoldering a 9v battery clip in an old Christmas ornament for a friend. The ornament is apparently designed to be a little smoke detector that fits inside a plastic enclosure that looks like a christmas ornament. The circuit is a piezoelectric buzzer and what I would assume to be the smoke/heat sensing element. In the picture you can see there are two terminals and it apparently seems to be in series with the buzzer(there is one black wire coming from the buzzer that is connected to a terminal of the “sensor.” I connected the positive supply terminal to the other end of the “sensor.” In the middle there is a set of contacts. I don’t recall what this is specifically but it almost seems like it functions like a relay arm but if I close the contacts the alarm buzzes. It looks like the middle of the buzzer may function like a sort of relay too that can magnetically move it when they are lined up in the enclosure. I attached a picture and this looks old but any help would be appreciated. I don’t know how to find a place to start learning about how it works but it doesn’t seem like there is much to it.
