Hello everyone!
The board I am creating is a flight computer for a model rocket that has a barometric pressure sensor (BMP280) and an Inertial Measurement Unit (MPU-6050) to measure orientation, acceleration, and altitude. Additionally, the computer is designed to control 2 servos, as well as 4 separate "Pyro Channels", which use N Channel MOSFETS to drive a high current through a nichrome wire attached between 2 alligator clips, which are electrically connected to the board via a 2 pin screw terminal. Lastly, the board will have an SPDT on and off switch. The board will be powered by a 12 V LiPo Battery, whose voltage will be regulated down to 5 and 3.3 volts for different components. Before getting the board manufactured, I am also looking to add a buzzer and a few tri-color LEDs (the brighter the better) in order to add some visual flair, but I am having trouble finding SMD packages for these components, so any recommendations would be much appreciated. I am still in high school, so I have no formal EE education at all, and this is the first time I have expanded beyond the breakout boards, so I am fully expecting to see mistakes, and if you see any please point them out to me
![20210322_162244.jpg 20210322_162244.jpg](https://forum.allaboutcircuits.com/data/attachments/221/221022-315f5878a24c50241352a937e5a4d608.jpg)
This is the wiring from the Teensy 3.5 to the I2C sensors and to the regulated 5V power supply. Each I2C data line (SDA & SCL) has 4.7k Ohm pull-up resistors to 3.3V to prevent the data lines from going low when the sensor is not transmitting data ( I think). I didn't actually calculate these values but read online on Sparkfun that they should work. Pins 3-6 are connected to pyro channels, and pins 8 and 9 are connected to the servos
![20210322_162225.jpg 20210322_162225.jpg](https://forum.allaboutcircuits.com/data/attachments/221/221023-7c0a261d33c1f680001c94737a225dc3.jpg)
This is a voltage regulator that takes the 5V power supply and regulates it down to 3.3 V for the sensors. I was originally using this because I was planning not to use a development board and use the processor as a standalone, but after I couldn't figure out how to program a standalone processor (help would be appreciated), I switched to the Teensy, which can regulate down to 3.3 V for me, so I probably don't need this anymore
![20210322_162229.jpg 20210322_162229.jpg](https://forum.allaboutcircuits.com/data/attachments/221/221024-d80e6c9836951d581ca952d7b1fd1f11.jpg)
This is another Voltage regulator (the well-known 7805), that takes the 12V from the battery and regulates it down to 5V. I am pretty sure, from what I remember that 12 V is close to, or higher than the maximum input voltage for the Teensy, so I decided to be safe and regulate it down. The reason I am using a 12V battery is because I want to be able to use this board in things other than rockets as well, like robots, so I need the extra power to keep them running for extended periods of time. The circuit is just copied from the datasheet
![20210322_162234.jpg 20210322_162234.jpg](https://forum.allaboutcircuits.com/data/attachments/221/221025-eb3a5b9206419171eb8edea8ef33b9ac.jpg)
These are the servo headers for both servos on the rocket, and they will just be 0.1" male header pins in a row of 3, connected to pin 8 and 9 of the teensy.
![20210322_162237.jpg 20210322_162237.jpg](https://forum.allaboutcircuits.com/data/attachments/221/221026-878cdc38765a4e16794d669b71e3477b.jpg)
Now this on and off switch is something I am rather worried about. I could not find that many wiring examples of using an SPDT switch for on/off, so I built the circuit off my own intuition. I thought this would work, but now I realize that no matter what position the switch is in, power will be drawn from the battery. How do I make an on-off switch that doesn't actually draw power in the off position?. I read online that it is not good to keep pins floating, so I felt like I needed to connect the other side. Not sure if I make any sense, but help would be appreciated.
![20210322_162200 (2).jpg 20210322_162200 (2).jpg](https://forum.allaboutcircuits.com/data/attachments/221/221027-7b92360cfe4ea7d0289fd74bd09a4f9d.jpg)
This is the BMP280, a barometer which has popularity as a breakout. I just copied the circuit from the datasheet, but if there is any tip or anything anybody has for working with this sensor it would be great
![20210322_162208 (2).jpg 20210322_162208 (2).jpg](https://forum.allaboutcircuits.com/data/attachments/221/221028-62000a552a3ef180d78c4c452bd22cc5.jpg)
This is the MPU6050, the raw sensor without any breakout. Again, basically just copied the datasheet and tried to follow all the electrical specifications. However, if anybody has tips for me, I would gladly take them
![20210322_162217 (1).jpg 20210322_162217 (1).jpg](https://forum.allaboutcircuits.com/data/attachments/221/221029-7e56b2f105139eea98299c5cf7710dc6.jpg)
This is 1 of 4 pyro channels on the computer. This is basically how it works. 5V are passed from the MCU GPIO pin into an N channel MOSFET with a very low RDSon, and the high current is sent out a screw terminal block into a nichrome wire, which is not pictured below. The 10k pull-down resistor is there to prevent the MOSFET from accidentally activating, and the 510 ohm current limiting resistor is there to prevent the MOSFET from trying to pull too much current from the MCU pin in the instant it is activated
What I am really worried about is the fact that I might need some passive components or other things that I might not know how to use, and that will cause a failure in my circuit. However, if you see ANYTHING wrong or even slightly concerning please tell me as it would really help me out. Thanks!
Datasheets and parts: Note that I have not used some parts yet (like the buzzer and LED) Also this doc is like half notes so don't mind some of it
Buzzer | Buzzer Link | |||
Toggle Switch | Switch Link | |||
Screw Terminals | NA | 125 V @ 10 Amps | ||
5050 | LED | 5050 SMD Datasheet | https://www.adafruit.com/product/619 | |
T220 | MOSFET | https://cdn-shop.adafruit.com/datasheets/irlb8721pbf.pdf | 10 mA of current output on GPIO | |
Teensy 3.5 | Microcontroller | https://www.pjrc.com/teensy/techspecs.html | ||
Testing Pushbutton | ||||
MPU6050 | IMU | MPU6050 Datasheet | I2C Address: 0x68 | |
BMP280 | Altimeter | BMP280 Datasheet | ||
SG90 | Servos | http://www.ee.ic.ac.uk/pcheung/teaching/DE1_EE/stores/sg90_datasheet.pdf | ||
7805CV | Voltage Regulator | file:///C:/Users/jaysj/OneDrive/FC%201/Voltage%20Regulator%20Datasheet.pdf | Regulator Link | |
Flash Memory | https://cdn-shop.adafruit.com/datasheets/MB85RS64V-DS501-00015-4v0-E.pdf | |||
Battery | ||||
Alligator Clips | Clips Link | |||
Nichrome wire | 28 gauge Nichrome | |||
wire gauge tech specs | ||||
https://www.engineeringtoolbox.com/wire-gauges-d_419.html | ||||
Nichrome wire tech specs | ||||
https://wiretron.com/nichrome-resistance-informational-charts/ |
