looking for an op-amp with AGC
bug13
Joined Feb 13, 2012
2,002
Hi guys
Is there an op-amp with AGC built in? Or how can I implement one if not too difficult. Some how I can't find any op-amp with AGC built in, maybe I am looking at the wrong place???
I have multiple analog audio feeds with different signal strength going into a switch, I want constant output.
Thanks guys!!
Alec_t
Joined Sep 17, 2013
15,117
Won't active AGC inevitably introduce compression and hence give distorted audio? Or isn't that a concern?
Have you considered a passive mixer, with pots to adjust relative channel volume levels?
Audioguru
Joined Dec 20, 2007
11,248
Automatic Gain Control adjusts the gain. If its attack and release are too quick then it causes symmetrical odd harmonics distortion similar to clipping. Usually it has a fast attack and a slow release.
It distorts the dynamics of sounds. If music is playing then AGC causes the level of background sounds to be modulated by loud drum or bass beats. During a beat the level of background sounds is suddenly reduced then the level slowly comes up to normal but the next beat also suddenly reduces their level. On some songs the background music cannot be heard if there is loud drum or bass beats.
Some people think that AGC is needed for speech but I think it messes up speech.
In this circuit where inputs with different levels are switched on and off, when a lower level signal follows a high level signal then the beginning of the low level signal will be low level until the release time of the AGC slowly increases it.
PeteHL
Joined Dec 17, 2014
580
There is a circuit in a book in my library with the title "Audio Automatic Gain Control". The book is Vol. 3 of the Encyclopedia of Electronic Circuits (Rudolph Graf), from some time ago. This was originally in Pop Electronics 1968 (!).
The circuit includes MC3340 audio attenuator, an op amp (741), JFET 2N5485, and about 20 discrete passive components.
As I don't have a scanner, I would have to compose the schematic from the page. If you think that this might be what you would want, I could compose in LT spice or one of the other drawing programs that I have.
Regards,
Pete
bug13
Joined Feb 13, 2012
2,002
Regards,
Pete
Hi @PeteHL, thank you for your kind offer, I will most likely just use the MAX9814 or amplifier circuit with 3 different adjustable gains as other member suggested
bug13
Joined Feb 13, 2012
2,002
That’s an educational read, thanks!
