Logic level P channel mosfets
38,681
so how about the FQP27P06, is it any better?
Not really.
It's easy to determine if it is a logic-level device.
Just look at the Vgs(th) voltage, and the Vgs used to determine the ON-resistance.
The max Vgs(th) is usually 2V or less, and the Vgs to test the ON-resistance is 5V or less.
Below is an example of one:
22,105
@Papabravo
So in this post I was told that the IRF 4905 is not is it not a very good logic level P channel mosfet.
https://forum.allaboutcircuits.com/threads/555-voltage-booster.187006/page-5#post-1748651
My original assessment was based on the datasheet which showed Vgs(th) between -2V to -4V and rds(on) measured at Vgs = -10V, which would not be possible in a 5V system. Go back and check the edit to that post where a simulation with a model of unverified connection with reality shows that it might be OK.
https://forum.allaboutcircuits.com/posts/1748892/
Ian0
Joined Aug 7, 2020
13,227
It's rare that one would actually need a logic-level P-channel MOSFET, as it would imply that a large load connected between 5V and 0V was being switched.
A P-channel MOSFET is most often used to switch a load on a higher voltage supply, in which case it would not be a problem to use a standard MOSFET.
For instance, FQP27P06 can switch 20A - when would one need to switch a 20A load on the 5V supply?
38,681
It really depends upon the load current being switched, when the worst-case Vgs is no more that 1V above the maximum Vgs(th), (which is typically 4V for a standard MOSFET).
Wendy
Joined Mar 24, 2008
23,805
I think I understand, if the push button is pressed the LED will light.
Wendy
Joined Mar 24, 2008
23,805
Most 5 Volt power sources are in excess of 1 amp. I calculate 2.9ma.Not too much current I should think.
22,105
The power supply is NOT the issue. The forward voltage drop of the LED and the 1K resistor are the issue, because 2.9 ma will hardly allow a standard LED to glow brightly. You'd need a high efficiency LED to do that.
k1ng 1337
Joined Sep 11, 2020
1,038
I have ZVP2016 logic level MOSFET which works pretty good.
Gate-Source Threshold Voltage VGS(th): -1.5 to -3.5 V, | ID=-1mA, VDS= VGS
Static Drain-Source On-State Resistance (1) RDS(on) 5 Ω | VGS=-10V, ID=-500m
22,105
That is in the same ballpark as the BSS84 which did not perform particularly well in the simulation. It had an imputed rds(on) of 6.25Ω and dropped almost volt driving a 200 ma load.
k1ng 1337
Joined Sep 11, 2020
1,038
Link to this simulation? I've been using them for basic stuff so the high resistance has been negligible. The N channel is a more acceptable 2Ω :p
Wendy
Joined Mar 24, 2008
23,805
Yes, that is if there is enough current from the +5V source to actually light the LED.
weren't you questioning whether the five volts had enough current to drive an LED?
current to the LED is not important it is only an indicator nothing more. My experience with LED suggests that one milliamp would light it. If that's all I wanted to do which is frequently enough.
22,105
NO! A powerful supply cannot force more current into a 1K resistor than Ohms law will allow.
That approach doesn't work too well for products that need to be produced in volume; for breadboards you can do whatever you want.
Audioguru again
Joined Oct 21, 2019
6,826
The threshold voltage of a Mosfet is when it is almost turned OFF. Don't you want to feed the gate-source with a voltage that will turn all of them (the Vgs is a wide range of voltages up to 10V) ON?
Wendy
Joined Mar 24, 2008
23,805
So if I wanted to test one out I would use this scheme and then measure the voltage on the drain to calculate the IDS resistance?
Audioguru again
Joined Oct 21, 2019
6,826
Your 1k resistor is not in the Mosfet circuit.
5V/100 ohms is a current of only 50mA. If the current is higher then a Mosfet that needs 10V of gate to source voltage to conduct well will work poorly.
